Brake conversion.
Old Feb 27, 2009 | 11:15 AM
HHRthunder13's Avatar
Brake conversion.
Is their a brake conversion kit out there somewhere? Drums to rotors for the hhr. I cant find anything. Any suggestions?
Old Feb 27, 2009 | 12:52 PM
1Panel2NV's Avatar
You'll have to switch to a hhr ss or cobalt ss rear beam. I suppose you could also fab your own brackets.
Old Feb 27, 2009 | 01:12 PM
catdaddy137's Avatar
no help
i searched this the other day , i found 3 old posts , but no help. ss comes with rear disc ??? right??? if so how come no one has done this?? the reason i searched is i noticed some on a van , the uplander. i guess no chance of those fitting the hhr??
Old Feb 27, 2009 | 06:03 PM
1Panel2NV's Avatar
A couple people have done it to cobalts and at least one person, hvrod, has done it to an hhr.
Old Feb 28, 2009 | 12:17 AM
jeffs396's Avatar
Give Todd a call at TCE...
http://www.tceperformanceproducts.co...s.pl?record=27
Old Feb 28, 2009 | 12:47 PM
KHR's Avatar
KHR
Tce
Give Todd at TCE a call -I have Wilwood on front and back - 6 puck front,
4 puck back - 13 inch rotors
karl
Old Feb 28, 2009 | 06:51 PM
Todd TCE's Avatar
Former Sponsor
I could do Karl's rear kit again. But there's no parking brake either so you may find that something you don't like.
I could do a Wilwood p-brake caliper on perhaps a 11.75 up to 13" rear rotor also. And on the rear beam as done above. Cost would run about $1200 plus....something else you probably wouldn't like.
Sorry...not a lot of options!
Old Feb 28, 2009 | 08:59 PM
I'm giving this some thought, with the extra power I'll be getting from Hahn Racecraft's turbo, I'll be wanting much better brakes.
Does this need to be a local job, or is it in kit form?
Old Mar 7, 2009 | 08:29 AM
Todd TCE's Avatar
Former Sponsor
Both front and rear kits were bolt on. And if we did up a p-brake one it too would be bolt on. I don't offer too many kits that require excessive fab work. The only hiccup on a p-brake caliper is often the need for specialized cables and in the case of the drum to disc set up this would be true. I can only give you a contact for this and let you work with them on that part.
Old Mar 7, 2009 | 03:48 PM
CJH's Avatar
CJH
Here's another Company, SSBC... located on the East Coast. i'm running their Front & Rear Brake System on a 07 HHR Give them a Call
http://www.ssbrakes.com/
